ac compressor continuously on?
Old May 22, 2009 | 12:38 AM
justinsanders's Avatar
justinsanders
Default ac compressor continuously on?
should the ac compressor always be on when the ac is running or should it kick on and off? im asking because i have my compressor wired to a switch to lock the clutch. i couldnt get it to turn like it should by itself so i have a switch to turn it on when i want ac. i just leave it running all the time when im using it is this ok?
Old May 22, 2009 | 12:53 AM
ldiablo233's Avatar
ldiablo233
The AC compressor is running all the time on the belt. I believe it has a clutch and engages the clutch to the compressor wheel when its switched on.. would be nice to know since my AC holds fine, but isn't cold. Are you saying the clutch is always engaged?
Old May 23, 2009 | 12:22 AM
justinsanders
im asking if the clutch should always be engaged if the ac is running. since i have the clutch wired to a switch i was wondering if i should turn it on and off periodically while the ac is on so i dont overcharge the system or whatever. idk if i should just leave it on while im using the ac
Old May 24, 2009 | 12:43 PM
12 volt's Avatar
12 volt
the AC compressor is complety independent from the clutch. The only time it should be on is when you have your AC on, otherwise your just wasting gas and wearing out the compressor
