WHAT NOW SUCKA, project log
Old May 27, 2009 | 08:34 PM
berretta96's Avatar
berretta96
Default WHAT NOW SUCKA, project log
I'm finally going to do a project log....if you have comments or suggestion SPEAK UP :ireful:
the car is in the garage and apparently my wife thinks this is a new storage shelf. Pics of the car itself is coming soon!
SO, let me get you up to date.
I bought my Flame Red 96 Expresso Coupe (SOHC ATX) for $500 because it needed the ever famous speedo fixed and headgasket replaced. I started off N/A buy installing a K & N intake, pacesetter short tube header, magnaflow exhaust, msd coil, mopar wires, unorthadox UDP, megan racing test pipe, mopar performance ecm, APEXi Neo Gen
Through these bolt ons I was able to go from 92 whp to 122 (dynoed before and after). Next I swapped out the ATX for a 3:55 MTX. Along with a retune, I dynoed a whopping 132 whp and 138 lb of tq. Car was a lot funner to drive but still not worthy of racing.
I thought long and hard about wether or not I was ready to boost and finally started stockpiling some parts. I purchased a mattdog adaptor and srt turbofold and started the install (along with another couple dozen items LOL). I wasn't ever able to dynoe the car after it was boosted but I did tune it (via wideband) up to 8 PSI. The car was suddenlly FAST TO ME. I was very impressed with the car and shocked many others. After a few months, I started to get bored with the (assuming high 13 low 14 second) car.
NOW WHATS HAPPENING??? :shock:
I bought a 96 stratus engine that had broken a timing belt 60k miles. I also bought an 05 SRT engine that had thrown a rod 17k miles. So, now I have a good SRT head, SBEC block. I've stripped both blocks down to nothing. I will decide on internals when I find out how the stock bore is.
The srt head is currently at the machine shop http://www.moffittbratton.com/ getting the oil drain back port filled and drilled. Then it will undergoe a full race port and polish, including intake, exhaust, combo work, radius valve job. Once the head is prepped, I have BC springs and titanium retainers to install and BC stg 3 cams.
The secret too big power will be via Garrett 57 trim .48 a/r. This will be mounted on an HP Racing stainless tubular manifold with a 38mm external wastegate.
Tuning will be handled by MegaSquirt. I had a custom plug and play harness built also.
I'll take some engine pics as I put it back together...
Old May 27, 2009 | 10:39 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
tell your wife if she is not good to her (the car) she (your wife) will end up on the shelf.
GO REDWINGS
