How to remove rear seat?
Old Jun 1, 2009 | 06:12 PM
ldiablo233's Avatar
ldiablo233
Default How to remove rear seat?
How do you get the rear seat off? I see it seems it just pops up, but wouldn't budge....
Old Jun 1, 2009 | 07:26 PM
Captansavaho's Avatar
Captansavaho
the bottom piece just pops out...where the seatbelts are located there is hex screw thats pretty larger take those two out then push up and pull and the back rest portion will come off
Old Jun 1, 2009 | 11:04 PM
Nates_expresso's Avatar
Nates_expresso
About 1 foot from the door on either side is a clip that needs to be releaced. Push the bottom edge of the seat twords the trunk, and pull up. Repeat for both sides... The bottom is held in by a T55 or T60 torx bit where the seats come in, and then pull the seat up and it will come out.
~Nate
Old Jun 2, 2009 | 09:40 AM
das2123's Avatar
das2123
You might need some PB blaster and a cheater bar to break those bolts loose.
Old Jun 2, 2009 | 01:57 PM
Nates_expresso
PB blaster inside the car... no thanks...
Used my harbor freight electric impact gun with a harbor freight T55 torx bit, came right out (99 neon, Wisconsin/Minnesota all its life)
~Nate
