oil leakk
Old Jun 8, 2009 | 09:31 PM
dirt_track238's Avatar
dirt_track238
Default oil leakk
my dohc has an oil leak on the passenger side of the motor. it looks like it it coming from inside the plastic civer that goes over everything in the timing belt. i took of that motor mount today and looked in the best i could without taking the whole plastic cover off. does anyoneeeee have any suggestions on what is leaking the oil?? it is leaking onto my alternator(not good) and all along the frame.
Old Jun 9, 2009 | 01:25 AM
ldiablo233's Avatar
ldiablo233
There is a seal(s) where the cam goes into the head by the cam gear, if its lower probably head gasket. Only way to know for sure is probably take off the cover.
