How to adjust tranny belts???
Old Jun 17, 2009 | 03:59 PM
craigsharp's Avatar
craigsharp
Default How to adjust tranny belts???
How do you adjust transmission belts on a 98 Neon SOCH ATX??? I remember there used to be another website that showed how, but i haven't been able to find it... anybody care to elaborate on how to do it???
Old Jun 18, 2009 | 10:11 AM
12 volt's Avatar
12 volt
the transmission doesnt have belts. only belts i can think of are on the front of the engine
Old Jun 22, 2009 | 03:26 PM
9R/T.4door8's Avatar
9R/T.4door8
could you mean the transmission bands? they grab the drum that holds the clutches in the trans
Old Jun 22, 2009 | 04:38 PM
das2123's Avatar
das2123
KICKDOWN BAND
The kickdown band adjusting screw is located on left side (top front) of the transaxle case.
(1) Loosen locknut and back–off nut approximately five turns. Test adjusting screw for free turning in the transaxle case.
(2) Using wrench, tighten adjusting screw to 8 N·m (72 in. lbs.).
(3) Back–off adjusting screw 2 1/4 turns. Hold adjusting screw in this position and tighten locknut to 47 N·m (35ft. lbs.)
LOW/REVERSE BAND
(1) Loosen and back off locknut approximately five turns.
(2) Using an inch-pound torque wrench, tighten adjusting screw to 5 N·m (41 in. lbs.).
(3) Back–off adjusting screw 3 1/2 turns. (4) Tighten locknut to 14 N·m (10 ft. lbs.).
