Help Please
Old Jun 17, 2009 | 05:24 PM
avfd123's Avatar
avfd123
Angry Help Please
I have a 1995 dodge neon SOHC 5 speed. I was going up the interstate on the way to work the other night and the car just stopped running. I could not hear the fuel pump running. I replaced the fuel pump relay with the horn relay. I replaced the fuel pump fuse. I checked the codes and the car is throwing a code 12 and a code 42. I know the code 12 doesn't mean anything. I also checked the fuel pump itself and am not getting fire to the pump. I have recently replaced the timing belt also with no problems.
Where should I start with the code 42?
Thanks
Joe
1995 Dodge Neon, 5 speed, SOHC 156000 miles.
Old Jun 17, 2009 | 06:25 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Fuel pump relay control circuit problem Auto shutdown (ASD) relay control circuit problem No ASD relay output voltage at PCM
Fuel level sending unit - volts out of range
Fuel level sending unit - no change over miles
Use your multimeter and find where the power is lost.
Old Jun 18, 2009 | 09:15 AM
avfd123's Avatar
avfd123
Default 1995 dodge neon
Where do I use the multimeter to start looking for power loss to my fuel pump?
Old Jun 20, 2009 | 06:21 AM
Relentless2.0's Avatar
Relentless2.0
Change your camshaft position sensor an it will solve your problems. 
Old Sep 14, 2009 | 08:07 PM
bg1995redneon's Avatar
bg1995redneon
Did you ever find out what the problem was?
