Hello
Old Jun 21, 2009 | 10:30 PM
carltr's Avatar
carltr
Default Hello
Hello, im new to the forums. I figured this would be a great place to share info with other dodge owners. I just recently aquired a 1995 dodge neon and i plan on fixing it up quite a bit. First thing i would like to do is see if i can get some more bottom end torque out of it. Any ideas?
Old Jun 25, 2009 | 10:54 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
hey, welcome to DF! I'll move this over to the neon section for you. Those guys will have plenty of ideas.
Old Jun 25, 2009 | 12:01 PM
Ghost Neon 2's Avatar
Ghost Neon 2
To better assist you, tell us about your neon engine. Is it an sohc or dohc? What condition is you neon in. Had a recent tune up? Is your car a automatic or manual (5sp)?
Old Jun 26, 2009 | 01:37 PM
carltr's Avatar
carltr
Its in pretty good condition. Just a small 2.0 SOHC. Gonna do atune up this weekend. It has a automatic trans only aftermarket engine parts it has is a cold air system.
Old Jun 26, 2009 | 02:12 PM
ldiablo233's Avatar
ldiablo233
First thing should be manual swap
Old Jun 27, 2009 | 08:16 PM
Ghost Neon 2
For the time being, pull the pan on your automatic transmission, and replace the filter inside. Also clean the magnet attached to the atx pan. Also change oil, coolant (if not BRIGHT green), and brake fluid. New champion/NGK plugs (none of that pltinum BS-not good for neons), and a new air filter element(K&N).
