painting question
Old Mar 20, 2005 | 02:42 AM
MakinationZ's Avatar
MakinationZ
Default painting question
I wanted to paint the removable parts of the air vents.. But I was thinking when I run the heater will it get too hot for the spray paint.
Would this be too dangerous or is there another way I could color them? They are originally gray I want to spray paint them white.
Thanks
Old Mar 20, 2005 | 03:16 AM
RayDog26's Avatar
RayDog26
Default RE: painting question
u can check on the back of the paint you get for coloring panels to see how hot it can withstand or you could even buy high temp paint.. but i really don't think it gets hot enough to melt any thing cuz the plastic vents would melt too..
Old Mar 20, 2005 | 04:20 PM
98Neon4Door's Avatar
98Neon4Door
I rattle canned mine with some krylon red and it can get a little warm but it dosent run, tho after the heaters been on and then off for a while they will want to stick just a little because the paint heats up but they still look great.
Old Mar 20, 2005 | 07:49 PM
casper's Avatar
casper
Krylon makes a good plastics paint, Fusion I believe, that should work fine.
