Daytime Lights Dont Work
Old Jul 16, 2009 | 07:04 PM
shawn_selig29's Avatar
shawn_selig29
Default Daytime Lights Dont Work
hi guys, i just bought this neon... i notices the daytime light dont turn on when the car is on. i went to a junk yard and got a module from a caravan (2000) and thrown in it the neon... but yet the lights still dont work...
what should i check out/ replace next?...i need the daytime lights for my next inspection.
Old Jul 17, 2009 | 11:18 AM
das2123's Avatar
das2123
I assume you live in Canada, ey?
Did you check the fuses/relay?
Old Jul 17, 2009 | 02:05 PM
shawn_selig29
yes i live in canada.
im not sure where the fuses and relays are for it...can u help me find them?
btw,,, i was just told the neons from the US dont have the system.... i used a vin decoder from another site and got this info about the car:
Country Of Origin:
Belvidere, IL (USA)
Make:
Plymouth
Vehicle Type:
Passenger Car
Passenger Safety Options:
Active Restraints, Dual Front Airbags
Vehicle Line:
Neon [US/ Canada/ Export]
Series:
Sport
Body Style:
Neon Coupe
Engine Type:
2.0L SOHC
Check Digit:
3
Model Year:
1998
Assembled In:
Belvidere, Illinois - US/Canada/Export - MATCHED
Number Of Car Built On Line:
537915
so does this mean it is a US car?..... it got the daytime light module behind the radio, which i already replaced.... any help greatly appreciated...i just dont know where else to go with this problem. thxs, shawn
Old Jul 17, 2009 | 02:09 PM
das2123's Avatar
das2123
The fuse or relay will be in the PDC (power distribution center) just behind the battery.
It was built in Belvidere, but it was export matched so it is a Canadian neon. Basically the same, just a few minor differences like the DRLs.
Old Jul 17, 2009 | 04:43 PM
shawn_selig29
ok, thanks for the reply... would you happen to be able to tell me wat the fuse/ relay would be called or its position in the box?, thxs, shawn
Old Jul 18, 2009 | 12:14 AM
das2123's Avatar
das2123
The top of the fuse box will show the location of the relay/fuse.
Old Jul 18, 2009 | 09:09 AM
shawn_selig29
either im not missing it...or i just cant find it....i only see anything that resembles lights is the fuse....wich be the 40 amp i think...and it is good...
is there suppose to be another relay or something?... thanks for your help, shawn
Old Jul 19, 2009 | 08:23 PM
das2123's Avatar
das2123
There may be one on the inside of the car behind the headlight switch.
