built 2.4L turbo wont run right at all
Old Jul 29, 2009 | 09:28 PM
sabin420's Avatar
sabin420
check to see if ur fuel pressure regulator is flowing in the right direction...seeing as you can change the fuel pressure, I would believe you have an aftermarket regulator. I had the same problem w/ a 300ZX Twin Turbo...the lines going to the aftermarket fuel pressure regulator was backwards.
Old Jul 30, 2009 | 01:53 PM
justinsanders's Avatar
justinsanders
i have never replaced the regulator before i wanna do the spool boy mod does anyone know where i can find a complete how-to
Old Jul 30, 2009 | 11:21 PM
justinsanders
well im pretty sure i have a dohc atx comp in my 2001 2.4 turbo non ngc mtx. will this comp. cause me to not be able to go past 1/4 throttle without it runnin real bad??
i just dont know what else to check
Old Jul 31, 2009 | 01:18 AM
12 volt's Avatar
12 volt
you need a rrfpr and a map clamp.
sounds like the mixture is messed
Old Jul 31, 2009 | 01:04 PM
justinsanders
i have a map clamp on it and what kind of rrfpr do i get just one from ebay and i bypass the stock regulator right? do i need a return line
