'96 engine rebuild
Old Jul 27, 2009 | 05:26 PM
12 volt's Avatar
12 volt
Originally Posted by dipsherry
sure can the bottom ends are the same so if you find a sohc block you can just rebuild it and put your head on it
the blocks are the same on 96-98, the pistons on SOHC are different.
this post gives good info on engine differences
http://www.enginebuildermag.com/Arti...0l_engine.aspx
if yor planning on swaping heads this post gives info on head swaps.
https://dodgeforum.com/forum/1st-gen...c-to-dohc.html
Haynes is better than chiltons but try and get your hands on a factory service manual.
my advice would be to get a different engine that has good copmression.
