Low spark on #3....
Old Jul 25, 2009 | 03:34 PM
ldiablo233's Avatar
ldiablo233
Default Low spark on #3....
What would cause it? I changed the #2 and #3 wires to check if it was the wire, I also replaced the SP. I had a bit of oil in the tube from a seal leak that was there for a few days but I cleaned it up. I only checked it by pulling it and checking the spark against the tube itself but it didn't spark as much and wasn't as loud or bright. I need to find my voltmeter but until and suggestions? Also what should I set it under and what should it read for the spark?
Old Jul 25, 2009 | 04:36 PM
berretta96's Avatar
berretta96
corrosion on the coil or maybe a coil going bad.
Old Jul 25, 2009 | 10:11 PM
ldiablo233's Avatar
ldiablo233
Alright, I think I have an extra so I'll try that.
