everyone should switch to the srt oil filter
Old Jul 27, 2009 | 09:58 PM
justinsanders's Avatar
justinsanders
Default everyone should switch to the srt oil filter
i just realized that srt4 oil filter is the same size and exact same thread its just a bit longer for better filtration. so i figured well y not everyone should use that filter.
Old Jul 27, 2009 | 10:38 PM
12 volt's Avatar
12 volt
yeah .....i think the viper one is a little bigger
Old Jul 27, 2009 | 10:46 PM
justinsanders
wow even bigger than the srt filter? does it thread the same and is it the same width just a little longer?
Old Jul 27, 2009 | 11:30 PM
dipsherry's Avatar
dipsherry
yeah the viper filter is what i use
Old Jul 28, 2009 | 12:42 PM
das2123's Avatar
das2123
The Viper filter is a little wider but still seals fine. It is also a little longer.
Old Jul 28, 2009 | 12:48 PM
neoncrazy101's Avatar
neoncrazy101
I've thought about switching to the Viper filter, but the 3614 is what my mom and sisters car uses, plus we have 3 Neons that we drive. so its just raiser buying a bunch of 3614's.
Old Jul 29, 2009 | 09:30 PM
sabin420's Avatar
sabin420
the only reason you would need more filtration is if you don't take care of your motor like you should.
Old Jul 29, 2009 | 09:39 PM
neoncrazy101
good point.
Old Jul 29, 2009 | 10:10 PM
12 volt's Avatar
12 volt
basically the more area of filtering media that you have means you can trap more particles and still have the ability to flow liquid easily. not to mention the small boost in oil capacity.
u use Bigger filters on bigger engines because they make more carbon and other trash than our smaller engines. Therefore we dont require a larger filter because its not as easy to get them dirty as fast.
Old Jul 30, 2009 | 10:27 AM
spudsterier's Avatar
spudsterier
maybe i will give it a shot....the oil in my last work car was only changed 1 time in 30,000 miles....but then again it did also burn 3 quarts a week......
worth a shot though since im running low on my chrome oil filters anyways
