SPEED CHIP DODGE NEON
Old May 4, 2005 | 01:18 AM
  #21
ClearD's Avatar
ClearD
Default RE: SPEED CHIP DODGE NEON
hmm... [8D]
Old May 6, 2005 | 08:27 PM
  #22
highrevr/tflea's Avatar
highrevr/tflea
There is no way to get the resistor on a neon to work for hp gains b/c the air map sensor will cause it to run too rich. When this happens the detonation factor is involved ...sure wot will help expel the gas but unless u reflash your ecu or get stand alone or perf chip to compensate for the litre flo it causes to put out it actually does nothing and damages your motor. Its like adding higher litre flo injectors or pump without the upgrade... My sr20de deteriorated when I did that. And lesson learned...i will never do it again...
