1998 plymouth neon s.o.h.c need help badd
Old Jul 30, 2009 | 12:32 AM
Darin2126's Avatar
Darin2126
Default 1998 plymouth neon s.o.h.c need help badd
well i bought this car last week and im new to dodges buhh my problem is the grounding system is ****ed up im lighting my test light up with the body ground off and if i tough the test light to the ground and the body it ligets up buhh only if the abs a.c fuse is in buhh if i hook the body ground to the body and put tht fuse in it blows right up
Old Jul 30, 2009 | 01:25 AM
12 volt's Avatar
12 volt
what body ground are you talking about?
Old Jul 30, 2009 | 01:26 AM
Darin2126's Avatar
Darin2126
the one going from the negetive terminal to the body
Old Jul 30, 2009 | 01:30 AM
12 volt's Avatar
12 volt
is your battery dying
Old Jul 30, 2009 | 01:42 AM
Darin2126's Avatar
Darin2126
wat u mean lol nooo the ground lights up only when i plug in the a.c abs fuse in like its grounding out and send power through the ground buhh if i keep the fuse out the light stays off on the test light
