compression
Old Jul 31, 2009 | 11:58 PM
95neon1025's Avatar
95neon1025
Default compression
what is the usual compression for a 1995 sohc? i did atest and it had 180 on all 4
Old Aug 1, 2009 | 12:55 AM
ldiablo233's Avatar
ldiablo233
Thats excellent, with my rebuilt SOHC I got 160-165 and I believe the Haynes says 100 or below is not good.
Old Aug 3, 2009 | 01:10 AM
scraper neon's Avatar
scraper neon
yep 180 is good before i screwed a rod i had 180-195
Old Aug 3, 2009 | 12:51 PM
12 volt's Avatar
12 volt
direct compression test is 195-190psi. depending if its DOHC or SOHC
Old Aug 4, 2009 | 10:57 AM
95neon1025's Avatar
95neon1025
sohc and by direct do u mean the hose u screw in to the spark plug socket?
Old Aug 6, 2009 | 10:31 AM
12 volt's Avatar
12 volt
you could say that. seeing as youll need an air compressior to do the other comp test
