When I brake my headlights turn on and dash lights up
Old Aug 20, 2009 | 09:26 PM
Berettah's Avatar
Berettah
Question When I brake my headlights turn on and dash lights up
Just wondering if you guys had any ideas on why this is or how to fix it? Have recently resoldered the cluster as the Speedo was freaking out on me. Could it be a fuse or maybe just some dodgey wiring?
Old Aug 21, 2009 | 01:03 AM
12 volt's Avatar
12 volt
i would guess that you have a short in the cluster
Old Aug 21, 2009 | 01:48 AM
ldiablo233's Avatar
ldiablo233
I have similar, when I break my left turn signal(cluster only) stays on.
Would a short mean some two parts are touching where then shouldn't, have something in between them?
Old Aug 21, 2009 | 05:33 PM
Captansavaho's Avatar
Captansavaho
well the easiest solution to your problem is to stop braking..then they wont light up anymore
Old Aug 23, 2009 | 08:03 PM
Berettah's Avatar
Berettah
kool thanks, will pop the cluster out and have a look see.
Old Aug 23, 2009 | 10:41 PM
12 volt's Avatar
12 volt
A short circuit (sometimes abbreviated to short or s/c) in an electrical circuit is one that allows a current to travel along a different path from the one originally intended.
make sure you didnt bridge things together when you soldered the Cluster.
when did it start doing the brake light thing?
Old Aug 27, 2009 | 12:20 PM
Nates_expresso's Avatar
Nates_expresso
Grab another clusterSolder more carefully...
Make sure to transfer the odo over...
Old Sep 2, 2009 | 05:48 PM
Nikki24's Avatar
Nikki24
I've had the same problem with my 1995 Dodge Neon. Sometimes when I break the left turn signal lights up. I realized it's a wiring problem but it's not too much of a bother for me. What I've noticed is that when it happens you have to slightly move up the turn signal handle and the light goes off quickly.
