1st gen gauge cluster repair
Old Apr 14, 2007 | 03:51 PM
  #21
boxerjl2's Avatar
boxerjl2
Default RE: 1st gen gauge cluster repair
i thought maybe this would be it
let me know
[IMG]local://upfiles/60625/35F630D17EB14850B910BE75EF1F864E.jpg[/IMG]
Old Apr 17, 2007 | 03:42 PM
  #22
98neonsohc's Avatar
98neonsohc
Would this be the same spot to solder if I was trying to fix a speedometer that randomly drops to zero on a 98 plymouth neon with no tachometer?
Old Apr 17, 2007 | 03:48 PM
  #23
das2123's Avatar
das2123
You solder the back of the cluster...not the sensor.
Old Apr 19, 2007 | 04:12 PM
  #24
98neonsohc's Avatar
98neonsohc
Thanks this was the first repair I made on this car and now the speedometer is working fine, good call guys.
Old Apr 19, 2007 | 04:22 PM
  #25
das2123's Avatar
das2123
^^^Good to hear.
Old May 26, 2007 | 04:01 PM
  #26
jessika's Avatar
jessika
My sister has an 02' which lost all gauges last night. Would this fix apply to that year also?
Old May 26, 2007 | 08:45 PM
  #27
das2123's Avatar
das2123
ORIGINAL: jessika
I don't know if it would work on 2nd gens as they are data bus and 1st gens are not.
Old May 27, 2007 | 03:39 PM
  #28
jessika's Avatar
jessika
okay thank you so much for you reply! Even if it wasn't what i wanted to hear!
Old Jul 16, 2007 | 03:23 PM
  #29
smurf89's Avatar
smurf89
my gas gauge iz completly dead i thought it waz the gauge clusterso i boughta new one and itz still dead it worked 1 time wn i put gas in to my car and den it stayed dead
Old Jul 16, 2007 | 03:59 PM
  #30
das2123's Avatar
das2123
ORIGINAL: smurf89
I'd look at your fuel sending unit then. It's located in the gas tank.
