New to the Forum
Old Sep 9, 2009 | 12:42 PM
Gr8Britton's Avatar
Gr8Britton
Default New to the Forum
I have a 1998 Neon SOHC (>210k miles), 1998 Dakota 2.5L (>110k) and a 2003 Durango 4.7L. I found this forum while researching a problem with my Neon.
I just replaced the clutch in my Neon (factory original). Things were great for awhile but I had a battery light on. I thought it was because we had to add a new O adapter to the positive cable due to corrosion. However, it all of a sudden started draining the battery when sitting.
I read the code and it says 44 - Battery Temp Sensor, which I had never heard of before. Anyone know where this is located?
Old Sep 9, 2009 | 06:56 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Neo section,
FF
Old Sep 14, 2009 | 03:30 PM
das2123's Avatar
das2123
It is located on the front part of the battery tray. There is a small place for it. It is possible it has broken off or is hanging somewhere in the vicinity. This however will not cause the battery to drain. You will have to look elsewhere for that problem.
Old Sep 15, 2009 | 12:36 PM
Gr8Britton's Avatar
Gr8Britton
This turned out to be a funny story. When we were changing the clutch, I found a loose wire tucked in by my head light. When I pulled it out, it looked like a broken bulb. I pulled it off and threw it away.
As it turned out, it was the Battery Temp Sensor. I had NEVER seen the sensor in the spot on the battery tray before. So, it would appear that when I had the car in the dealer to have warranty work done, they broke the sensor and just hid it by the head light.
So, I bought a new sensor and tried to tighten it to the battery tray. And guess what...I broke it! However, as long as the sensor was in the plug, the battery light went off and the Check Engine light cleared. So, I used electrical tape to form a barrier around the wires, just like the old sensor did, and have put it back by the head light. I figured it wasn't work another $25! ;-)
Thanks for the reply.
Old Sep 15, 2009 | 12:41 PM
neoncrazy101's Avatar
neoncrazy101
my BTS broke off a long time ago.... it just hangs below the battery tray now lol
Old Sep 15, 2009 | 12:47 PM
das2123's Avatar
das2123
Thats the case with all of my neons!
Old Sep 15, 2009 | 10:22 PM
Altima_wb's Avatar
Altima_wb
lol dude i don't remember ever seeing a bts lol... i'll have to take a closer look at my dohc and see lol... i know its not by the battery like it should be so maybe its hanging down...
