Car Will Not Start
Old Sep 23, 2009 | 11:11 AM
hcbarclay's Avatar
hcbarclay
Default Car Will Not Start
Lights work and all electricals seem fine, without testing...car won't turn or make any noise! This morning it hesitated but finally started. The man who towed it for me thinks it's some sort of a relay issue...it's a 96 Neon...HELP please! This is my girlfriend's car and I am desperately trying to fix this for her. I am decent under the hood. Let me know if there is anything else you need to help me out. THANKS!
Old Sep 23, 2009 | 08:09 PM
neisg1's Avatar
neisg1
It could be the starter relay in the power distribution center near the battery try swapping it with another relay. Could also be:
1) Clutch switch manual trans. or park switch Auto trans.
2) 30A starter Fuse power distribution cener
3) Ignition switch
4) Bad battery connection
5) Bad starter
Old Sep 24, 2009 | 07:17 AM
hcbarclay's Avatar
hcbarclay
Default location of these things...
could you help me with that? its also an automatic and im gonna be checking these things all day today so please respond as often as possible. thanks.
Old Sep 24, 2009 | 08:46 AM
hcbarclay's Avatar
hcbarclay
ok just looked at those things except for the park switch...how can i visually tell if the relay for the starter is bad?
the 30a fuse seems to be intact...unlesss there is something i dont know about fuses
Old Sep 25, 2009 | 01:04 AM
neisg1's Avatar
neisg1
There should be several relays the same just swap it with one of the other ones.
