Key on key off produced the following flashes and one with knowledge please help me.(does not start)
1-2-3-5-4-3-4-3-5-5
12=battery disconnected within the last 50 starts
35=open or shorted condition detected rad fan relay
43=multiple cylinder misfire
43= multiple cylinder misfire
55=end message code
12 and 55 are OK
43 is generally bad plugs and/or wires
this engine was running last weekend when i pulled it out of a donor car, would they go bad in between? someone suggested that i check for old gas and hook the exhast up, any thoyughts?
thanx
Kevin
thanx
Kevin
I'm not sure how code 43 is sensed but. I believe it can also be a fuel or injector problem.
