changing rear struts
Old Oct 18, 2009 | 01:11 PM
1998neonrtstock's Avatar
1998neonrtstock
Cool changing rear struts
i am also changing the struts in my 98 neon when i change out the struts do i need to have an alinment done on the back wheels
Old Oct 18, 2009 | 04:54 PM
spudsterier's Avatar
spudsterier
you should have ti done, but you can get away without doing it
Old Oct 18, 2009 | 07:02 PM
neisg1's Avatar
neisg1
When I changed mine the new ones had slotted holes and eccentric bolts so in my case I had to have them aligned.
Old Oct 18, 2009 | 09:44 PM
1998neonrtstock
ok well i would just be swaping them from the 95 neon i just got they are still good
Old Oct 20, 2009 | 12:08 PM
Nates_expresso's Avatar
Nates_expresso
Well, as an undercar tech, here's my opinion...
If you trace the lower part of the strut with a marker (marking the relationship between the strut and knuckle), you will have the same camber settings as the old struts did...
Depends on how long it's been since it was aligned, and if it was a 4 wheel alignment or not. It really doesnt matter much if you rotate your tires every few oil changes, but, you should have it done regaurdless due to milage, pothole impacts, and spring sag. WIth the new higher ride hight, it will be off.
Make sure to torque those bolts to at least 140ft lbs, else you get problems with camber changing itself in hard turns...
~Nate
