95 neon motor swap need help
Old Oct 20, 2009 | 01:56 AM
bbaker2088's Avatar
bbaker2088
Default 95 neon motor swap need help
sohc to dohc motor trans in and the motor wont roll over with key but can jump starter and it will spin. ive tried everything
Old Oct 20, 2009 | 07:49 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Neon section,
FF
Old Oct 20, 2009 | 11:05 AM
92dak5.24x4's Avatar
92dak5.24x4
im thinking it would be pretty simple to figure out the wiring problem start with a good quality wiring diagram to save a lot of time. trace out wires check for continuity and go from there. if you still cant figure it out, just install a push button on the dash for the starter solenoid
