Purge valve solenoid and park neutral switch help
Old Oct 21, 2009 | 07:48 PM
spixxor's Avatar
spixxor
Question Purge valve solenoid and park neutral switch help
The check engine light on my 96 neon came on. Codes it threw at Autozone were CR401 (park neutral switch) and PV300 (purge valve solenoid) . Can anyone tell me where these are located on the car and how easy it is to fix these problems? Thanks.
Old Oct 21, 2009 | 09:08 PM
neisg1's Avatar
neisg1
The purge valve solenoid is located just to the right side of the timing belt cover beside the A/C hoses. It has an electrical connector and several vacuum type hoses. The park neutral switch screws into the side of the transaxle, access from under the car.
