97 neon is it my Engine or Tranny going???
Old Nov 2, 2009 | 12:02 PM
bg1995redneon's Avatar
bg1995redneon
Originally Posted by neisg1
You can build you own leak down tester.In the photo of mine, the fitting between the two gauges is plugged and then drilled with a 1mm or .040" bit to calibrate the air flow.
http://www.supraforums.com/forum/sho...d.php?t=520536
http://www.motorcycleproject.com/mot.../leakdown.html
Thanks for the info. and the links, but how much did you pay for all the parts? The reason I ask is that you can get a tester at Harbor Freight for $40.
http://www.harborfreight.com/cpi/cta...emnumber=94190
