10.5:1 comp with nitrous
Old Nov 17, 2009 | 11:39 PM
Relentless2.0's Avatar
Relentless2.0
Default 10.5:1 comp with nitrous
Hi i am rebuilding my engine and thinking about putting in 10.5:1 pistons but i use nitrous. I was wondering if that would be ok or too much on the crank or rods. Its gonna be stock rods an crank with wiseco forged pistons. By the way its a SOHC. Really need a answer quick cause im gonna order tomo. Thanks!!!
Old Nov 22, 2009 | 09:59 PM
ottoretto's Avatar
ottoretto
ummm bro, i used 150 shot on a stock sohc, maybe u can use iunno 60 shot, of course u can use nos, but its better if u start with a small shot and then will gettin bigger i think 80shot will be top!
Old Nov 22, 2009 | 10:57 PM
Relentless2.0
You say you used a 150 shot, did you have to retard your ignition timing? I want to go to like a 75 or 100 shot but I don't have an aftermarket ignition system. I've read every where that you have to if you wanna go past a 50shot. I decided to get eagle rods so they will be able to handle it. Plus it's a auto so I can't get a PCM from modern because there's are only for manuel tranys
Old Nov 23, 2009 | 11:55 AM
ottoretto's Avatar
ottoretto
and ur car is atx?? bro i didnt retard the ingition, i retard the cam, used good spark plug, msd coil, thats it, wet shot! let me see if i can make some system to retard u spark...
Old Nov 25, 2009 | 12:13 AM
Relentless2.0
So then I wouldn't need an aftermarket ignition system? And yeah it's a atx. I don't wanna go mtx. What you mean by you'll see if you can make me one? I don't know any way of being able to retard my ignition timing because I have an atx... F****** blows!! Tired of a 50 shot
Old Nov 25, 2009 | 11:46 PM
ottoretto's Avatar
ottoretto
lol! i was meaning that i can make some system to retard the spark, look u can handle the nos if u improve ut spark i mean use the msd coil and try tu buy some voltage elevator, its used like and msd box, improving the voltage to the coil for multiply the output spark, let se what i can do for ya!
