95 Not Charging
Old Nov 23, 2009 | 08:29 PM
sgetty's Avatar
sgetty
Default 95 Not Charging
I replaced the alternator and battery, checked all the wires,grounds etc? thinking pcm? does the P/N from a used one have to be the same?
Old Nov 24, 2009 | 12:12 AM
ottoretto's Avatar
ottoretto
it cannot be the pcm, check the wires on the fuse box!, can be cutted!
Old Nov 24, 2009 | 02:23 PM
sgetty's Avatar
sgetty
but the regulator id in the computer so couldnt that be the reason
Old Dec 1, 2009 | 04:12 AM
Altima_wb's Avatar
Altima_wb
yeah if the alternator and battery test good and your wires are in good shape then its most likely your pcm... right on any new alternator you buy for a neon it states that the voltage is regulated by the pcm... so if everything else checks out its time for a new pcm....
Old Dec 2, 2009 | 10:48 AM
sgetty's Avatar
sgetty
thank you, i just got the new pcm yesterday and it was the problem..
