1999 r/t wont start/fire
Old Dec 20, 2009 | 10:37 PM
cpsvr6's Avatar
cpsvr6
Default 1999 r/t wont start/fire
i recently purchased this car and im starting to think i shouldnt have.. its turns over but wont fire.. sprayed some starter fluid in the intake.. still motor wont fire.. back fired 2 times.. and one have any ideas? beside junking the car???
thanks
cory
Old Dec 21, 2009 | 05:30 AM
mr340's Avatar
mr340
Muscle Car Moderator
Sounds like a timing belt, how many miles on it?
Old Dec 22, 2009 | 04:05 AM
Altima_wb's Avatar
Altima_wb
there is a lil inspection cover on the timing belt cover remove that and turn the engine over and see if the cam gear is turning that will let you know if the timing belt is good or not...
Old Dec 24, 2009 | 06:50 AM
mr340's Avatar
mr340
That will only tell you if it is not broken, if it jumped thaty won't really reveal it.
Old Dec 24, 2009 | 10:24 AM
Ghost Neon 2's Avatar
Ghost Neon 2
I had a similar issue recently. Remove the negative battery cable for 30 minutes. Put the negative cable back on, and try to start the car. Probably will not start. Check for codes:
[quote]Q: My Check Engine Light (CEL) is on, what do I do?
A: To read any codes on your neon, put the key in the ignition and cycle it to ACC on-off-on-off-on within 5 seconds. As the CEL flashes, count the number of flashes. This represents the code. An example would be flash-flash-flash-flash, pause, flash-flash-flash, which would be a Code 43, single or multiple cylinder misfire.
Check the codes you get against this: https://dodgeforum.com/m_63384/tm.htm
From here we can better assist you and your situation.
