Tail lights......Breaks, blinkers dont work??
Old Apr 16, 2005 | 03:36 AM
98Neon31's Avatar
98Neon31
Default Tail lights......Breaks, blinkers dont work??
I just installed some euro's on my neon and now my blinker slash break lights dont work but the stop lights work and when i looked at the bulb it looked fine and the fuse is new i know that its the green and orange wire ( major) which doesnt seem to have a short in it so i need someone to let me know what is going on any ideas??...... thanks
Old Apr 16, 2005 | 11:39 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Tail lights......Breaks, blinkers dont work??
You confused me...first you said your brake lights/blinkers don't work, then you said your brake lights work. Anyhow, if your blinkers or brake lights aren't working, make sure to check light bulbs to make sure none are burned out. Then I would check your fuses. Check the ones inside the car and also under the hood. If none are blown and your bulbs are fine then your multifunction switch is probably burned up, could be your flasher as well. But I can pretty much guarantee you have at least one fuse blown if your brake lights aren't working.
Old Apr 16, 2005 | 05:07 PM
nightstreetneon's Avatar
nightstreetneon
i had the same problem like the driving light would glow but my brake and turnsignal would. the bulb was fine but i replaced it and then it worked fine.
