oil on spark plugs
Old May 20, 2005 | 07:09 PM
mechengineer201's Avatar
mechengineer201
Default RE: oil on spark plugs
thanx smart ***
Old May 20, 2005 | 07:18 PM
mechengineer201
or pull the 20amp fuel pump fuse instead
Fuel pump? excuse my ignorance and lack of wiring diagrams but does that really cut power to your ecu? A 20 amp circuit is alot power at 12 volts, 240 watts actually - sure that doesnt route thru a relay to the pump motor?
Old May 26, 2005 | 02:15 AM
ATL Neon's Avatar
ATL Neon
ORIGINAL: mechengineer201
The car does learn how you drive to a certain extent
Adaptive strategy is the technical term - neural network programming algorithms for you computer geeks . Computers that learn - scary **** if you ask me. And dude - why did you take your car to the dealer? you def got ripped and there are plenty of good independent mechanics that know the neon backwards and forwards. If you want to get around the computers learning curve you can just erase its memory - kind of like you or I smoking a few tubes - jk - just disconnect the battery for a minute or so, you can do this in your driveway I hope, to bleed the capicitors in the puter, its just a jumbled mess of RC circuitry so give it a some time and you should be back to a nice to some nice fresh ram ready to learn again... As for your A/C issues, i highly doubt this would solve them and the knocks you are hearing are most likely not at the frequency of a "harmful" knock or the computer would retard the timing to prevent this - only a very narrow band of frequencies are considered harmful to an engine and most likely yours puter uses a band-pass filter to amplify them but thats more than anyone needs to know. If you are really worried about it have your girl use some higher octane gasoline, after you have reset the ecu of course. I have no doubt that if the car has been dogged around all its life that you have some nasty lookin combustion chambers and piston faces but if the tech that replaced the head gasket had half a brain or any pride in his work he woulda cleaned that **** off while he had it apart. And if I were replacing a head gasket you can bet your *** I woulda had the head milled - this raises the compression ratio - find out if they did that and if so I would def recommend running the next highest octane rating....good luck.
Its running a lot better now since i disconnected the negative on the battery to let the computer reset and floored it a couple of times to clean some of the crap out of it. I'm also gonna run some of that Techron fuel injector cleaner through it too. Thanks for all the info, I don't know a ton about the history of the car but it appears to have been pretty well taken care of looking through the receipts they have on it. I have no idea as of the details of what was done on the head gasket repair. I just know that it was done last summer by a "family friend" mechanic back home in Boston where she is from. She moved down here to Atlanta for grad school at Emory. The reason I took it to the dealer is because her parents were paying for it and they felt better about taking it there. Thanks for all the help, I'm a decent mechanic but I dont know **** about OHC cars. I've always driven trucks or Jeeps and learned what I know from working on them.
Anyone know of a good place in Atlanta to take her car next time it needs something done thats over my head?
Thanks a lot everyone.
Old Aug 13, 2006 | 04:37 AM
white96neon's Avatar
white96neon
how much did it cost to fix the oil spark plug problem
Old Aug 13, 2006 | 10:56 AM
neoncrazy101's Avatar
neoncrazy101
ORIGINAL: white96neon
The gasket(with tubes) for me from autozone ran about $30.... and i just changed mine yesterday....just make sure you dont break any of the bolts [:@]
Old Aug 13, 2006 | 03:59 PM
ATL Neon's Avatar
ATL Neon
Wow, I just got email noticifcation of this. I totally forgot about this, she sold the car. It turned into a huge money pit at 80K miles and it wasn't worth putting the money into it.
She has an '06 Sentra SE-R now, much nicer car. It only having 2000 miles on it is nice too.
