95 Neon - Stalling / Running rough
Old Jan 14, 2010 | 01:57 PM
Keeprrunnin's Avatar
Keeprrunnin
Default 95 Neon - Stalling / Running rough
I have a 95 SOHC w/auto, and from time to time, it has been stalling after braking quickly, then running rough wanting to stall after its been re-started. Then the next morning, it will be fine, until a fast brake happens again...??? It's a So Cal car, all stock, no mods.. I was thinking.. fuel filter? or perhaps sediment in the tank that gets thrown forward, blocking the fuel pickup?? I don't know of anything to add to the fuel tank for cleaning, or breaking down of the particles.......?? If there is such a thing?? A fuel filter is roughly $25, $30, and easy enough to change on a 95... I thought electrical, so I put a new set of plugs in first, and it did not help. I thought coil pack, but that should not be triggered by braking. EGR valve, that should not be triggered by braking. Plugged catalytic converter, perhaps?? So Cal car, all original exhaust..? I know of cases where internals of cats get moved around, from bumps or panic stopping blocking the exhaust from flowing... Any and all suggestions are very welcome.
Old Jan 14, 2010 | 02:00 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Vacuum leak.
