95 neon loses power
Old Apr 20, 2005 | 02:49 AM
95slammed4doorneon's Avatar
95slammed4doorneon
Default 95 neon loses power
when i am driving down the road it seamss to loses all power and it chuges for a few min then its fine what could it b?
Old Apr 21, 2005 | 12:34 PM
RadarLove's Avatar
RadarLove
Default RE: 95 neon loses power
Is the Check Engine Light coming on at all?
Most common causes are a faulty Throttle Position Sensor, Crankshaft Position Sensor, or the wiring for those. Sometimes a busted cat could do it, a few other sensors could do it, clogged air filter, clogged or faulty injectors, clogged fuel filter (aluminum tank models), failing fuel pump, etc.
Old Apr 28, 2005 | 10:50 PM
95slammed4doorneon
my light comes on and then will goo off i huked it up to the scanner at and it said throttle position what on is it tho so i can replace it is it the on closes to the front seats or the front bumper
Old Apr 28, 2005 | 11:02 PM
SlowAssNeon's Avatar
SlowAssNeon
the throttle position sensor is located directly on the throttle body...
heres a how-to on removing the 1g throttle body:
http://www.neonspeed.com/howto/howto..._tbremoval.htm
when removing the TPS (throttle position sensor) please be very careful, as those screws that hold it on have been known to break. you can either use a star-bit, or a regular socket, i believe the socket size is 8mm.. i prefer to use the socket, havent had a single screw snap on me yet that way.
Old Apr 30, 2005 | 04:43 PM
RadarLove's Avatar
RadarLove
It may not be the TPS itself though. Check the wires going to it to make sure they aren't rubbing up against something sharp (like the valve cover...). I went through 4 TPS's before finding my short.
Best of luck!
