head swap
Old Jan 18, 2010 | 03:21 PM
racingneon's Avatar
racingneon
Default head swap
Hello,
can I swap the head off a single cam and put it on a twin cam block?
Old Jan 18, 2010 | 07:39 PM
1fast2liter's Avatar
1fast2liter
yes you can.. make sure you have all the manifolds and such to go with it... matter of fat keep the dohc ecu to and go with a header and intake right away.. with a sohc head on a dohc bottom end your looking at about 10-1 compression.
Old Jan 19, 2010 | 05:32 AM
Nuklhed074's Avatar
Nuklhed074
also get a cam from a 95 its more aggresive which i happen to have if your looking for one
Old Jan 19, 2010 | 05:01 PM
1fast2liter
or better yet get a cam from a 2001 or 2002 r/t equivalent to a crane 12 cam.. also get the springs and retainers from one too.
Old Jan 19, 2010 | 08:31 PM
Nuklhed074's Avatar
Nuklhed074
yeah good luck i almost had my hands on one the decided to go boosted
Old Jan 20, 2010 | 10:55 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Here are your stock sohc cam shaft specs.
Here are sohc crane cam specs.
The 2001 magnum cam has more lift than the preceding magnum cams. The stock 2002-2004 magnum cam has the same lift as the crane #10 came, but the crane #10 has greater duration. The crane #10 is closer in performance to the magnum cams than the crane #12, which out shines them all.
Old Jan 20, 2010 | 11:25 PM
1fast2liter
right but as i was saying the r/t or magnum cams from the 01 up are better to use then a 95 cam.
Old Jan 23, 2010 | 10:38 AM
Zanko's Avatar
Zanko
Can you take a Sohc block and put a Dohc head on it?
Old Jan 23, 2010 | 03:12 PM
1fast2liter
yes.. but it would be lower compression then even a sohc.. to the tune of 9.3-1 or somthing like that.... if your gonna turbo it then it would be great.. other wise your gonna want to do pistons too.
Old Jan 24, 2010 | 06:41 PM
Nuklhed074's Avatar
Nuklhed074
i also have a set of dohc pistons also lamo
