Brake problems
I've been driving for a good month now on all the new parts, the front brakes seem fine, the passenger side piston was cracked, so I'm thinking that was my problem up front. No more leaks with the new master cylinder, BUT I can't seem to shake this pulling problem with the rear brakes.
I don't know what it could be. I took everything apart today and looked it all over again, and I have everything in the proper places, all the springs are fine it seems. The brakes seem to be adjusting, both sides were right out to the drum surface when I removed them. There are new drums, shoes and wheel cylinders on it. I don't know what else it could be.
I'm ruling out the hydraulics entirely. It also still pulls when I pull the e-brake. It still gets worse as the brakes get hot. I could see it being the e-brake cables themselves if it only did it when engaging the e-brake, but could they be a factor as well even though the problem persists under regular braking?
There are hardly any more components I can think of to replace other than the e-brake cables and all of the springs. This problem is starting to get really annoying. This car is very mechianically sound other than this, and at 67k miles I shouldn't have this type of a problem in my opinion.
try replacing the rubber hoses the go to the Caliper to the brake lines. sometimes the corrode on the inside and collapse, even though the outside looks fine. This causes the fluid to be traped between the caliper and the clog. while everyone thinks the calipers are sticking it is just a build up of pressure inside the lines.
My milage on the tank before fixing the line was 24mpg. After replacing the line my milage jumped to 28mpg. Same roads, driving habits, and even filling up at the same pump. I also had a high idle issue that develeped right before the first tank. I finally had time to look at it after that second tank and found a cracked vac line between the PCV and the intake mani. I replaced that and this past tank I hit 30mpg.
Thanks to everyone for their input.
