CAI?
Old Apr 22, 2005 | 05:56 PM
ClearD's Avatar
ClearD
Default CAI?
I was thinking of building my own cold-air intake, but I own a 98 SOHC Auto and space seems to be limited...is there any way this can be done to route the intake into one of the holes in my front bumper over there?
And, if not, where's the best place to route the tube?
Old Apr 22, 2005 | 06:21 PM
chud298's Avatar
chud298
Default RE: CAI?
I'm pretty sure you could do it like the iceman. Put your battery in the trunk and send the intake down where the battery used to be. You might want to get a bypass vavle though because water will probably get in, unless your car is only a weekend type car.
Old Apr 22, 2005 | 06:23 PM
ClearD's Avatar
ClearD
Default RE: CAI?
nope, daily driver. bypass valve sounds like a good plan, and thanks! are there any other options?
Old Apr 22, 2005 | 06:50 PM
chud298's Avatar
chud298
Default RE: CAI?
Other than that I can't think of anything. I have the DOHC and I'm pretty sure the SOHC is set up the same and there's really not a ton of room in the front lol. The way I have it is the filter is in back of my enigne or behind the head, from AEM. I still get some hot air but it works awesome.
Old Apr 22, 2005 | 08:17 PM
ClearD's Avatar
ClearD
Default RE: CAI?
ok, that's fine I like the battery idea! Right now, my filter is almost directly above my header, so it's not exactly doing anything...the only difference is it's polished aluminum and bigger than stock [:'(]
Old Apr 22, 2005 | 11:06 PM
SlowAssNeon's Avatar
SlowAssNeon
Default RE: CAI?
yeah, having the filter directly over the exhaust manifold/header doesnt help much
you could do the iceman or 3.0 intake.. but theyll have to be shorter than those with the manual trans because the atx does take up more room. its still a lot better than sucking hot air from off the manifold tho!
Old Apr 23, 2005 | 03:18 AM
chud298's Avatar
chud298
Default RE: CAI?
ORIGINAL: SlowAssNeon
That's why they call it a CAI lol, that's why I feel kinda dumb having it in the back, but that's what a hood scoop is for . That'd cure my problem. If you have it where it's only sucking in hot air, might as well keep on the stock one lol.
Old Apr 25, 2005 | 01:37 PM
ClearD's Avatar
ClearD
Default RE: CAI?
lmao indeed
Old Apr 27, 2005 | 05:57 PM
jimmasterK's Avatar
jimmasterK
Default RE: CAI?
I did the Caravan 3.0 intake jobby. Nice little gain it gives. Easy enough to do on a SOCH ATX. But you'll be needing a Sawzall if you have the radiator with 2 fans.
Old Apr 27, 2005 | 07:52 PM
ClearD's Avatar
ClearD
Default RE: CAI?
o, I think I do...can you gimme some details on that? I can get a caravan intake really easily, probably really cheap, too...
do you have to move the battery for that one?
