need help
Old Feb 8, 2010 | 12:12 PM
crazydesigns's Avatar
crazydesigns
Default need help
so i went to get my inspection today and failed i have a fault code p0134 o2 sensor circuit no activity detected bank 1 sensor 1 i replaced 02 sensor and got 3 not readys on kmy test first one for 02 sensor second for egr sys and third for catalyst do i just need to drive it until they reset or is there a way to so this cause ive had the fault code reset already and went back and still failed any ideas would be nice
Old Feb 8, 2010 | 12:49 PM
das2123's Avatar
das2123
If you have had the PCM reset, you will need to drive the car for about 50 miles so the sensors will "be ready" for testing.
I have had this happen after replacing my spark plugs and disconnecting the battery.
Old Feb 8, 2010 | 12:57 PM
crazydesigns
ok thanks and also stil lhave code for battery being un hooked to lol stil lbut guessing that wil lreset over time to
Old Feb 9, 2010 | 09:56 AM
bg1995redneon's Avatar
bg1995redneon
Yes, your codes on the system will be 12 and 55 - assuming that everything else is OK once you disconnect the battery.
