does any one know if...
Old Feb 9, 2010 | 08:29 PM
streetracer88's Avatar
streetracer88
Exclamation does any one know if...
I have a 96 neon and i am swapping a 2000 neon motor into it i know the cam shaft position sensor is different on the 2000 head but i figure i could just splice the wire into my old harness and another question is does anyone else know what other sensors are different please let me know thanks
Old Feb 10, 2010 | 01:03 PM
das2123's Avatar
das2123
You will need to use your current intake and exhaust manifolds. Any sensors that won't plug into your current harness from the '00 engine, just swap in your current '96 sensors.
Old Feb 10, 2010 | 04:24 PM
streetracer88
thats what i figured i just wasnt sure if any were really different i was told the cam shaft sensor def. has to be changed and there is no way around it thats why i figured i could splice in the plug from the other harness is that really true that i cant use the cam shaft sensor?
Old Feb 10, 2010 | 10:27 PM
das2123's Avatar
das2123
I dont think there is a difference with the camshaft sensor. You may be thinking about the 2.4 swap where you need to flip the sensor if you use the 2.4 cams.
