Cylinder head locating dowel?
Old Feb 27, 2010 | 12:51 AM
waffles's Avatar
waffles
Default Cylinder head locating dowel?
Hi, I'm doing a head job on a 97 DOHC and one of the locating dowels poking out the top of the motor broke off inside the head. Does anyone know where I can get a replacement? Possibly a part number? Or maybe anyone have a solution to this problem?
Old Feb 27, 2010 | 08:12 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
I am not even sure what you are talking about. can you elaborate a bit more. never heard of what your talking about.
Old Mar 1, 2010 | 11:40 AM
bg1995redneon's Avatar
bg1995redneon
I think you are going to have to go to your local machine shop and take both the head and block with you, as I would bet that any fix would involve grinding or drilling out the old insert from the block and putting in a new one.
That is of course assuming that it can be done. I have never see one break off before, but the shop will be able to tell you if it can be fixed and how much.
Good luck.
Old Mar 6, 2010 | 02:18 PM
waffles's Avatar
waffles
Good luck.
Ended up making one myself out of a 3/8 inch craftsman socket and used a dremel to get the broken one out of the block, lol. I've had to replace them on Chevy motors when they'd come back from the machine shop, they just tapped in. I also did a set on a BMW I did a head job on a couple years back (apparently this is a common problem on Bimmers). Just couldn't find one for the Neon. By the time I was done drilling and cutting the socket, it tapped into the block and you literally could not tell the difference lol
