Sunroof leak -- i need help
Old Mar 1, 2010 | 05:11 AM
Topsy's Avatar
Topsy
Question Sunroof leak -- i need help
Hi
I am new to forum
can anyone tell me where I find the sunroof drainage holes on a Chrysler neon as I cannot see them?
Old Mar 1, 2010 | 07:42 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcoem to the site. Check out the Neon sections or I can move this thread if you tell me the year of your Neon,
FF
Old Mar 1, 2010 | 11:36 AM
Midnight Runner's Avatar
Midnight Runner
Welcome to D.Forum.
Old Mar 3, 2010 | 05:57 AM
Topsy's Avatar
Topsy
its a chrysler neon 1998
Old Mar 3, 2010 | 07:50 AM
1969CoronetR/T
vaffanculo
I will move this thread to the first generation Neon section,
FF
Old Mar 4, 2010 | 10:40 AM
bg1995redneon's Avatar
bg1995redneon
Default Posted 9/27/09 by jefster4117 - HTH
water in floorboard i just had this happen to me. i thought it was air conditioner related but it wasnt. After close observation found water leaking from side kick panel.i have a sunroof and the pass. tube was clogged up. There is 1on the front of the sunroof each side.
do any of you guys with tis problem have a sunroof? I almost never thought of the sunroof drain lines becoming stopped up! I mean the car is 10yrs old and it has never happend before. The car has always been parked under tree. Its a pain n the a** 2 keep clean.
Old Mar 5, 2010 | 06:34 AM
mr340's Avatar
mr340
Muscle Car Moderator
There is a drain tube in all 4 corners of the sunroof mount. You will need to remove the glass to access them. I usually run a length of #8 wire thru them and then a shot of compressed air to clean them out. I do mine yearly.
