1gn Pt Cruiser Clutch Install Questions
Old Mar 6, 2010 | 08:37 PM
96NeonJunk's Avatar
96NeonJunk
Question 1gn Pt Cruiser Clutch Install Questions
Guys i was looking 2 use a pt cruiser clutch in my 98 neon. Should i use the 2.4 n/a clutch, or the 2.0 n/a clutch, i know both are modular set-ups wanted to see if any you guys out there are running one....do we use the neon throw out bearing or pt's? any help seen alot of post on neons.org and have generaliztion on the set-up....heard the pt clutch is rated for a additional 30 ft lbs over neons clutch...any help or intel on set-up would be appercaited.
Old Mar 6, 2010 | 10:58 PM
das2123's Avatar
das2123
Use the 2.0 N/A clutch with the neon's TO bearing.
Old Mar 6, 2010 | 11:18 PM
96NeonJunk's Avatar
96NeonJunk
Good deal, thanks very much...
