timing?
Old Mar 11, 2010 | 11:34 AM
ohioguru's Avatar
ohioguru
Default timing?
Just retimed my motor. But its slighly laggy. Does that mean I'm a tooth off? And if I got a adjustable cam gear would that be easier to adjust ?
Old Mar 11, 2010 | 01:20 PM
thecause17's Avatar
thecause17
Why not just set the timing properly? You'd have to remove the belt to install a cam gear anyway, why not just reset it?
If you're unsure if it's even off, just remove the timing cover and turn the motor to TDC and see if the marks line up on the gear and the rear cover(I think in the DOHC case there are two marks on the cam gears that will line up). I'm sure you know this if you went through doing the job already.
Old Mar 11, 2010 | 04:11 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
yes, I just did a timing belt on my car and it ended up a tooth of on the exhaust. but, it seems as if your saying that you have a SOHC anyways the directions that came with mine were to
Put the crank one half tooth before TDC
align the cam gear
place the belt on the Crank, then the water pump, cam gear, and the idler. place 23ft lbs of pressure on the idler pulley and replace the tensoner. if done correctly the allen wrench will come out easly.
Old Mar 12, 2010 | 08:29 AM
ohioguru's Avatar
ohioguru
I did. Bent my wrench. But its just a pain in the *** to do. Since I don't have air guns. And it was a Half tooth in front. But would a adjustable cam gear be easier if It was all ready installed? I have never used one and don't know how they work. I know lines up every 2 rotations.
Old Mar 12, 2010 | 11:18 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Reset the timing properly. I have never used or required an air gun to set timing.
Old Mar 14, 2010 | 07:07 AM
ohioguru's Avatar
ohioguru
Ok. I've done it with and without. Its just faster. But seriously I know how to reset timing what I don't know is the question I asked. Would someone answer it!
Old Mar 14, 2010 | 10:34 AM
DOHCgarrett t3
he ha I suppose you could use a adjustable timeing gear to reset the timing if you were only a tooth off. but nothing more than that. the cam gears only advance 5 degrees and retard 5 degrees. and you would still get the code 11 because the magnets are on the other end of the cam.
Old Mar 15, 2010 | 11:34 AM
ohioguru's Avatar
ohioguru
and 1 more thing....im not coding. weither its 3 off or 1. would that be related to the fact im running a 95 cam?
