95 neon speedometer off with bigger tires
Old Mar 18, 2010 | 12:12 PM
ia89dakota3.9's Avatar
ia89dakota3.9
Question 95 neon speedometer off with bigger tires
does any body know how to correct the speedometer for different size tires on a 1995 neon
Old Mar 18, 2010 | 01:23 PM
Captansavaho's Avatar
Captansavaho
i dont believe there is a way.. unless you move the needle itself?
Old Mar 18, 2010 | 08:19 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
even moving the needle wont help though, when I had my trans done on my crown vic my needle was off, it would say 100 when I was only doing 80. I had to change the VSS gear. Not something they make for the Neon that I am aware of.
Old Mar 20, 2010 | 09:19 AM
thecause17's Avatar
thecause17
What size tire did you have and what did you go to?
I think all of the tire sizes in the 1st gen Neon still had the same overall height, so I'm guessing that there is no option as far as a change on that gear. I'm not sure if these cars are anything like my truck, but my trucks tire size is programmed into the computer, and the dealer can reprogram it if I change sizes and make it match what I have. I have a Superchips programmer for it, so I can do it myself though. I'm not sure if the Neon computer is like this.
Old Mar 20, 2010 | 09:39 AM
neoncrazy101's Avatar
neoncrazy101
Nothing to do cept know how much its off by. http://www.neons . org/tire/ (take out the spaces) If you go there then you can see how much your off by. I know at 65mph I'm off by roughly 1mph with my 195/60-R14's
Old Mar 20, 2010 | 09:58 AM
Tizzy1's Avatar
Tizzy1
If you have an automatic transmission, there is a gear on the speed sensor in the transmission that is offered in a 20 tooth or 21 tooth version. It gives you alittle adjustment anyway.
