obd2 questions?
Old Mar 20, 2010 | 09:33 PM
dirt neon's Avatar
dirt neon
Default obd2 questions?
ok, a friend of mine brought over a snap-on scanner and pluged it in. I got 5 codes... po462,po403,po122, po118,p1899. I think we found a couple of them but not to positve anyone know the codes? also it said about the spark timing was 12 degrees btc.. is that good or what should it be? thanks for the help
Old Mar 21, 2010 | 12:05 AM
Neongreg88's Avatar
Neongreg88
how does he car run... the scaner should of told u wat it is.... could be EGR,VACUM LEAK 02 COULD BE BAD timeing could be off or it could of jump... the timing belt....
Old Mar 21, 2010 | 01:56 PM
dirt neon's Avatar
dirt neon
it runs fine when its cold but as soon as it warms up it boggs out while in gear but if i push the clutch in or put it in neutral its fine and will rev up.
Old Mar 21, 2010 | 10:29 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
sounds like a bad Cam sensor.
