Neon No Spark No Fuel
Old Oct 23, 2010 | 12:19 AM
xotic kaos's Avatar
xotic kaos
Default xotic kaos
Originally Posted by defopimp05
Hi, my 1995 Dodge Neon has absolutely no spark. Turns over fine but no spark no fuel.
Think it might be the computer.
Tell me what you think.
Thanks
IT could be the computer thats what my neon has and i chang the crank senser and the cam senser and still no spark or fuel the next thing to do is chang the computer
Old Oct 25, 2010 | 06:19 AM
2002ACRNEON's Avatar
2002ACRNEON
If the fuel pump (computer) fuse is bad, loose, etc., the motor will crank but you get no spark or fuel.
Make sure that circuit (power and ground) are good first.
Old Oct 27, 2010 | 01:21 AM
Rabies_00's Avatar
Rabies_00
Cool What's ur code??
Click your key forward 3 times and tell us the code. The crank sensor sends signal to the ecm to start the firing sequence.
Old Aug 15, 2013 | 09:17 AM
viruscloud2001's Avatar
viruscloud2001
I had the same problem with my neon... check ur fuel pump fuuse if its blown... I would go straight to the wires for ur oxygen sensors one of them may be grounding out.
