Cams Questions!
Old Mar 22, 2010 | 08:34 PM
ottoretto's Avatar
ottoretto
Default Cams Questions!
hi guys, well i need some ifno about the dohc cams, i installed a 2.4l on my neon, but the engine its froms a stratus, so i wanna install the 2.0 dohc cams on my 2.4l, cuz this cams are hotters, what i need to do for swap the cams?
Old Mar 23, 2010 | 09:03 AM
das2123's Avatar
das2123
Just use the 2.0 cams. The 2.4 head is the "same" as the 2.0 head. The biggest difference is the block.
Old Mar 23, 2010 | 02:26 PM
ottoretto's Avatar
ottoretto
yeah i know that, ok das2123, i used the 2.0 cam, and bro the car start but iunno how to say, failing a lot!, its like to much fuel, the car barely got idle, and still need to acelerate the engine, and do not pass the 4500rpm, i smell a lot fuel... what else i need to do? play with the cam degrees? cam sensor?
Old Mar 23, 2010 | 03:08 PM
das2123's Avatar
das2123
Did you rotate the cam magnet 90°? You have to do that in order to get the timing correct. Your 2.4 crank signal is 180 crank degrees or 90 cam degrees off from your 2.0's crank signal.
Old Mar 23, 2010 | 07:13 PM
ottoretto's Avatar
ottoretto
oh i didnt xD im so stupid!!! xD gonna try that!... the car gonna improve with the 2.0 cams? stock cams!??... and thanks!
