1st and 2nd gen tranny swap
Old Apr 9, 2010 | 04:49 PM
jonsed77's Avatar
jonsed77
Default 1st and 2nd gen tranny swap
I am just wondering if a tranny from a 01 sohc neon will bolt to a 95 sohc block? Need to know before i buy a tranny and find out the hard way that it don't fit. Thanks
Old Apr 9, 2010 | 09:19 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Yes it will bolt up. The bell housing are different, so you will have to swap then to make it work correctly.
Old Apr 13, 2010 | 10:40 PM
das2123's Avatar
das2123
Manual or automatic?
Old Apr 14, 2010 | 10:16 AM
jonsed77's Avatar
jonsed77
Sorry I should have specified. It is standard.
Old Apr 14, 2010 | 10:42 AM
das2123's Avatar
das2123
As mentioned, you will have to swap bellhousings as the 01+ transmissions are hydraulic. The 95-00 transmissions are cable.
