crankshaft questions
Old Apr 10, 2010 | 06:11 PM
ottoretto's Avatar
ottoretto
Default crankshaft questions
hi everyone, i was wondering if i can use a 2.4 (stratus, caravan) crankshaft on 2.0 block making some customs rods?? using the same pistons?
Old Apr 14, 2010 | 11:10 AM
das2123's Avatar
das2123
I would not think so, as the blocks are different. I haven't had a 2.0 and 2.4 crankshaft side by side to compare either though. Maybe go to a parts store and compare.
Old Apr 19, 2010 | 11:26 PM
Nuklhed074's Avatar
Nuklhed074
kinda on the same subject... 2.4 head fit the 2.0 block? what about internals..thanks in advance
Old Apr 19, 2010 | 11:40 PM
das2123's Avatar
das2123
Heads are the same, internals are not.
Old Apr 19, 2010 | 11:49 PM
Nuklhed074's Avatar
Nuklhed074
thaaaank you much thats what i figured wouldnt it change compression due to the difference in the size of the combustion chambers..one being a 2.4 and the other being a 2.0?
Old Apr 19, 2010 | 11:55 PM
ottoretto's Avatar
ottoretto
guys i found a 2.4 engine, complete, heheh, i need to do sumthing for take out the balanced shaft, i can removed without any problem?
Old Apr 20, 2010 | 12:10 AM
Nuklhed074's Avatar
Nuklhed074
not sure on these motors most the time though yes i removed the balance shafts on my sohc 4g63 in my 88 mighty max and havent had a problem at all maybe a little shakier than stock thats about it
Old Apr 20, 2010 | 12:45 PM
ottoretto's Avatar
ottoretto
well if u say so, maybe i can be the same, these engine use if for run smoothly, cuz got a long stroke, fue that shake can destroy the engine?
Old Apr 28, 2010 | 09:40 PM
Nuklhed074's Avatar
Nuklhed074
i dont think the shake could hurt the engine..or atleast i wouldnt think so
