96 neon gauges messed up?
Old Aug 17, 2010 | 11:00 PM
parrotbay's Avatar
parrotbay
Default 96 neon gauges messed up?
ok so i have a 96 neon and the speedometer went first, then the light behind the temp , then i started it one night and the lights for both blinkers were flashing. Ive noticed that if i hit on the dash really hard in the right place it will make everything work again. Any ideas?
Old Aug 18, 2010 | 04:29 PM
fig_neon's Avatar
fig_neon
mine does the same thing the speedometer will work when I first start mya car during the day then it will just drop when I'm driving shortly after. It works for awhile but then it drops and stays down. Don't know why? Help?
Old Aug 20, 2010 | 06:57 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
resolder the points on the back of the cluster. search for the how-to.
Old Aug 20, 2010 | 07:24 PM
tjnorton13's Avatar
tjnorton13
agreed. neons have horrible gague cluster problems. (found this out the hard way) its probalby the conection points on the back of the cluster. mine ended up being a spedo gear in the tranny but we wont go there lol....
Old Aug 22, 2010 | 09:29 AM
DOHCgarrett t3
That would be called the VSS gear.
Old Aug 22, 2010 | 11:47 AM
parrotbay's Avatar
parrotbay
are there any other clusters that i could replace it with ?
Old Aug 23, 2010 | 11:31 AM
DOHCgarrett t3
you can replace it with any 1st gen cluster with or without an RPM gauge.
