check engine light question
Old Aug 20, 2010 | 06:54 PM
tjnorton13's Avatar
tjnorton13
Default check engine light question
iv got a 96 neon sohc mxt. ive done a axt TB upgrade, my question is this; will doing this make the check engine light come one with a code for fuel mixture is to lean? i understand that increasing the TB size adds more air to the mix, but would it be the cause of this trouble code? because if so im just going to ignore it :P, i added the tb to add more air.
ne help is much appriciated. thanks.
Old Aug 20, 2010 | 06:56 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
unhook the battery for 1 minute then reconnect, the ECU should re-learn the new values. either that or the TPS sensor is bad?
Old Aug 20, 2010 | 07:21 PM
tjnorton13's Avatar
tjnorton13
what do u mean unhoock the battery and the ecu should learn the new values...... iv had the batt. out several times since i put it on.
Old Aug 23, 2010 | 04:30 PM
DOHCgarrett t3
so if the code then keeps comming back maybe try swaping the other TB back on or swaping the TPS sensor.
