Dash help?!
Old May 26, 2005 | 08:01 PM
LilRedNeon97's Avatar
LilRedNeon97
Default Dash help?!
How the heck do I take the dash apart? I want to put in glow gauges but I don't know how to get in there. I didn't wanna just start pullin on things just hoping that it pops open. A little help guys!?!
Thanks!
Courtney
Old May 27, 2005 | 12:31 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: Dash help?!
HEHE just pull the dash apart ........LITERALLY!!! The top piece comes off with a snap no screws so pull away and itll only take ya 10 mins to do the install.
Old May 30, 2005 | 06:44 AM
RadarLove's Avatar
RadarLove
Just get the heel of your hand under the lip above the instrument cluster and push up. The whole dash lifts off... Then there's 4 screws that hold the cluster in, and just pull it off the connectors in back. There are 5 or so screws holding the clear plastic cover to the cluster.
Best of luck!
Old May 31, 2005 | 06:28 PM
ClearD's Avatar
ClearD
hey, I actually just put glow guages in about 2 days ago. here's some advice: MAKE SURE YOU LEVEL IT ON A COUNTER AND REMEMBER EXACTLY WHERE THE NEEDLES WERE POINTING BEFORE YOU TAKE THEM OFF!!!! The needles will move and screw up your guages if you're not careful. I did it to the speedometer and the temp guage. BE CAREFUL! I ended up following my mom doing exactly 60 on the highway and it only looked like 45! I had to pull the needle out (while moving) and put it back in at 60. so, make sure you let it settle and remember where it was before you change it.
Old Nov 27, 2005 | 01:04 PM
fleneer's Avatar
fleneer
Re: needles pointing where they should... I've had the same misaligned needle problem before. Here's what I learned to do.
Before you pull the instrument cluster turn the ingition switch to "run" but don't start the car. This will "zero" the gauges. Make a note where the needles point. Then after your work on the cluster, with the lens off you can plug the cluster back in and turn the key to "run" with the engine off and place the needles on the gauges. This will get the needles where they were before the disassembly.
Old Nov 28, 2005 | 09:31 PM
casper's Avatar
casper
LOL, the problem is you guys took the needles off. You don't take them off at all, just move them as needed to get the face over. The gauges 0 out themselves.
